1964 rear drum brakes
Hi all,
I need a picture of the rear drum brake with cylinder mounted between the welded on bracket which extends to either end of the cylinder. The cylinders I ordered as replacements fit between the bracket but only if I remove the dust boots. Otherwise they are a mechanical precise fit between the tabs on the bracket. I wish I took a picture!! Arrrgh!
http://i58.tinypic.com/jh4o5e.jpg
Thanks,
Greg
Thanks,
Greg
Happened to me too. I shaved a fraction off the lip of each cylinder with my bench grinder and replaced the dist boot. Just enough to clear. I have driven the car extensively since then including the track day at the corvette museum under hard conditions with zero ill effects.
I would assume 63 had the same setup....I used all NAPA parts and rebuilt EVERYthing and it all fit fine...
I like the story behind your car! 4.56 gears would be fun!
Yes I was in a hurry - fixed the picture...doesn't help much anyway as you can't really see your problem area. I have all the NAPA part numbers for my brake job if that will help...including wheel cylinders; that is -- IF they will work on a '64.
Received 1,126 Likes
I sell in my store either Dorman or Centric wheel cylinders for these cars.
Dorman - W13387 & W13388
Centric - 134.64005 & 134.64006
If you can not find them let me know.
Joe
Joe
As an update, I was able to find my old cylinders. They are the same length as the ones I bought, but slightly smaller in diameter. The last guy had the same problem. There is a small cut in the boot from being jammed into the bracket. Those in Frankie's picture are definitely shorter. Will try to find some of those.
Joe, thanks for the part numbers. I have not looked locally yet. Do you have a price shipped to Mass. 01583?
Thanks,
Greg
Thanks,
Greg
Received 1,843 Likes
Thanks,
Greg
Thanks,
Greg
POSSE ZR-1 Driver
Get the correct cylinders front and rear and be done.
If the OP has switched to front discs, then the front to rear brake balance is changed, and I have no suggestion for that case.
64luke (09-19-2015)
Either you or me is confused on the issue. I take it his outer dimensions are larger, not the bore diameter.
Here is the NAPA invoice (part of the whole brake overhaul) from 2013....everything worked perfectly after installation and still does.
The cylinders are apparently the Dorman part numbers also offered by Joe above (plaidside)...
Here are the Dorman wheel cylinder that I just got in.
Let me know if this is OK, if not I have another set coming in this afternoon from a different manufacturer. It measures approx. 2 7/8".
Joe
Joe
Joe,
Those cylindrs you sent worked great. it was a tight fit but not so much to pinch or cut the rubber boot. Thank you for for hooking me up. I was ablr to swap them without dis-assembling the whole brake set. Pease post the part details for others that may come across this post.
Thanks!
Greg
Thanks!
Greg
