No fuel on initial startup
I just posted this on my other thread , but that one is getting pretty long an probably a lot of people won't look at it. I fired up my solId lifter 427 today ( apparently I am not supposed to call it an L71 for some reason) and I can keep it running by dumping fuel down the vent tube, but it is not sucking any fuel from the tank, I have had it running for a few minutes but the line is bone dry, I installed a new fuel sender / pickup , and the motor is fresh with a brand new fuel pump, just wondering if you need to prime the system, , when I installed the pump I just stuck it in the block with the gasket and bolted it up, was there any other pieces that should have gone in first?
Is the push rod in there?...
It rides on the cam and pushes the arm on the fuel pump...
Just got an email from Tom that sold me my tranny, and he asked the same thing, no I did not install ant pushrods , too many things to think about when you only do this once every decade or so, thanks for your response , I am sure that is what it is.
If it isn't something simple
i can lend you $3 so you can actual put some in the tank!
When you put the 'push rod' in there..on the front of the block opposite of the rod, there is 3/4" bolt that needs to come out, put in your rod then put in a longer bolt 1.5" 'slightly tighten' it to hold rod up onto cam....put fuel pump on....NOW TAKE OUT LONGER BOLT PUT BACK IN THE SMALLER BOLT...put some sealant on the bolt to keep it form leaking oil...
if your block is black use 'black rtv'....
i thought it was funny! Jack had you covered prior to my joke!
At least i am not the dumb person and especially if you did it more than once, pouring raw fuel into a carb (recipe for disaster being a good way to cause a fire and to damage your engine!!).
Received 1,857 Likes
