spin on oil filter for my C1
hi guys, some years ago I converted my c1 oil filter to a spin on , only after years of sitting the label has fallen on my oil filter what number oil filter are you using ??
I belieive it was the same as the 1978 corvette spin on .
many thanks, grumpy
many thanks, grumpy
The conversion unit on mine uses a PH8A Fram. That is a Ford filter. Heaven forbid!
NAPA 1060 Gold or NAPA 1794 if you want 2 qt capacity.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
MOST, but not all, of the spin on conversions used the same filter which was used on 68-later Chevy engines (68 was the year the switch was made).
My personal choice for ALL of my engines is the longer truck (2qt) filter.
hi guys , great , I have to use the short one my header collector is below the filter, many thanks, grumpy
Received 1,267 Likes
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
Good luck,
Plasticman
Wix 51069
K&N Filters
My 61 has Hooker Headers and it get's a bit crowded when trying to remove a regular oil filter so I went to K&N filters because they have that hex adapter on the bottom and I can remove it with a socket.
Mike T - Prescott AZ
Received 1,126 Likes
Can you post a picture of the sealing gasket on the filter.
There were at least two types of filter conversion kits used.
Some used the Chevy filter as mentioned and some, such as the one on my 61 FI car, uses an 'F' or Chrysler style filter.
Post a picture and I will give you the numbers.
Joe
Joe
It will either be a wix 51060 if there is a bypass in the adapter and it's 13/16" thread. Or it will be a wix 51515 if there is no bypass in the adapter and it's 3/4 thread.
Different companies have made them both ways.
Last edited by XCSP700; 07-16-2015 at 09:01 PM. Reason: I had the sized wrong, Thanks plaidside
I stopped using the AC filters since they 'down sized' them. So here are the ones I use and the differences.
The PF454 is the replacement for the old PF25, notice how short it is compared to the Wix equivalent, 51069.
The PF1218 is the replacement for the old PF35, the Wix 51061 is the equivalent for the old PF35, without a check valve. I do not believe you need one since the filter is vertical.
The 51060 is the same as the 51061 but with a check valve.
If your conversion kit uses 13/16-16 thread and 3.444" OD gasket then you can use either the 51069 or 51061.
If it uses 3/4-16 thread and gasket OD 2.834" then either use 51515 or the 51068.
PF454, 3" tall
PF1218, 4.375 tall
51069 and 51068, 4.338" tall
51060 and 51515, 5.178" tall
PS. Wix makes for NAPA, they just drop the first digit. 51061 = 1061, 51515 = 1515.
Joe
PF454, 3" tall
PF1218, 4.375 tall
Joe
