60 C1 - Side spears fitment on a new front clip
I've replaced my front clip and there are no holes or markings for where the spears need to go. Does anyone have any suggestions or templates or best practice for ensuring the are fitted correctly by correct positioning of the elongated holes to the side of the coves and holes to the front of the coves?
Thanks in advance
Mick
Thanks in advance
Mick
Best I can do - not near the car right now...this is PS of a '61...original car...note front spear holes are slotted.
How hard would it be to make a card board piece fit in the cove. Using your old take off parts ( some of the scrap should have enough left to spot the holes ) trace and drill. If your car didn't have the front clip attached... time to let your fingers do the walking.
Measure the spears, measure the attaching points on the spears. No rocket science here. There are only three to fit in the opening.
It appears to me from the AIM that the vertical, black backing piece that is tucked inside the cove may have three holes for the forward-pointing stud for the spears already in them (see red arrows). If that's true you should be able to measure that and draw a level, horizontal line from each of those holes rearward and hold the spear with the forward facing pin in the hole with the other pins pointing upward and get their location along that line. Drill a couple of holes to create a 'slot' at those points and that should work.....right ?
Be careful as EVERY spear is different...each of the 6 goes in a SPECIFIC spot.....
I mark such things on the back of the piece with a sharpee; e.g "PS UPR", "DS CTR", "PS LWR", etc...
