I just got my first C1 on the road
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I thought I'd be smart and change the diff fluid to a modern synthetic. Now I have a leaking gasket.
Received 1,901 Likes
Our '62 has always been fairly comfortable while driving.
I never have thought it too rough.
Obviously, like others have already stated, it doesn't handle like a newer updated performance car, but it's still a blast to drive!
Never heard of synthetics "eating gaskets". One of my first tasks on my '63 was to swap in synthetics in the leaking muncie and differential after gasket changes....about 3 years ago and still leak free. And the change actually cleared up a synchro clash when downshifting from 2-3 quickly...
Between work and out to dinner I had time to change the diff fluid. standard 75-90 gear lube. Also put new valve covers on with a PCV set up.
Received 3,443 Likes
Synthetic lubes don't eat gaskets. But they do leak a lot more if you have imperfect sealing areas. This is due to the make-up of the oil. The polymer strands are all the same size. Imagine a room with nothing but marbles on the floor, all the same size. That's synthetic oil....with identical symetrical polymer strands. Imagine a room with marbles, bb's, baseballs, basketballs, golfballs, etc. on the floor. That's regular oil. The polymer strands vary. That's why dino oil is less prone to leak. It doesn't flow as well. That said, synthetic oil is NOT recommended for Muncie or T-10 transmissions due to leakage issues and the possiblility of over-slick synchro rings. If it works for you, great, but research tends to tell us to avoid synthetic oils in these old cars....at least in the gearboxes and rear ends. I'm a big fan of synthetic oils in my newer stuff.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Kidding....omg, that's friggen gorgous!
Since I'll be pulling the axles to replace the diff gasket, I guess I should replace the outer seals as well. Are these the "Rear end outer axle housing gaskets" as in page 137 of the Corvette Central catalog? P/n 581017.
I drive a stock '61 and a stock '63 on the same day MANY days. They each have their idiosyncrasies. The C1s are primitive....straight-line driving is as good as many classics and the suspension is adequate. Its a pig in fast turns even with radials. The '63 is more refined, doesn't really ride all that much better but handles sweetly -- the all drum brakes can get exciting on panic stops....best to have the lane beside you empty when doing so....
My 63 SWC is 4spd, manual brakes and steering. Same in that Dept. Nice to have a 62 convertible when it is 95 outside. the 63 coupe is an oven.
#33
I would certainly agree Frank. My two C1s handle OK considering their ancient technology. But a few years ago my boss at the time asked me to test drive a '64 Corvette he was considering buying. I have to admit the difference was significant. He bought it and still has it I believe. The independent rear suspension was quite an improvement IMO.
#34
#35
Jack
#36
That's one nice 59. Prettier than most girls
#37
A stock C1 has been described as a 'fast tractor' and that's prob not far off. Its really late '40s steering and suspension technology so it can be a handful. I drove my '61 around Sebring on a sanctioned 'touring lap' and hit triple digit speeds twice -- my life flashed before my eyes and I saw a bright light beckoning so I slowed down. The car was a handful to put it mildly.
The '61 is like -- well, like driving a real car, predictable, well-behaved and you don't have to be 100% focused on operating it. BTW, $1,300 and about 15-20 hours of work will air condition a '63 and will make it even MORE pleasurable to drive...
#38
#39
