muncie tranny rebuild kits
hi guys , does anyone make a rebulid kit for Muncie 4 speeds??
gaskets all the bearings , etc ??
are some kits better than others ??
what do they go for ??
many thanks, grumpy rob
I haven't used any of these vendors, but here's some to start you off.
http://www.autogear.net/motorsports/
http://www.5speeds.com/cart/index.ph...tegory&path=33
http://www.thegearbox.org/Muncie.html
Received 1,125 Likes
I have been using Larry at D & L Transmissions for years and have excellent success with his kits. They are complete and high quality.
He if very knowledgeable and helpful.
Joe
1-631-351-4837
Joe
1-631-351-4837
Both Paul and Larry are Authorized A.G. distributors. Its refreshing to see people interested in quality, not a cheap kit with lots of extra junk added in.
If you don't have a front nut wrench, you can buy a cheap one (There are some nice high quality ones out there but you're looking at a ~$40 price point). If you buy the cheap one, it is definitely a "one shot deal". Do NOT use the wrench to take off the old nut. Only use it to install the new one.
We had caged needle bearings for the cluster gears made. You now have a drop in solution to the 112 loose needles. We only had them made for the 1" countershaft pin size though. If your hands are stiff, it can be hard to pack those needles in, and it removes the opportunity to drop a couple on the floor LOL. Certainly not a necessity however.
I'd give Paul Cangialosi a call (Really Nice Guy)...even if just to get more education. It's Free.
RK
hi guys , very had a problem with the needle bearings , few beers and we used Vaseline , the theory was when the tranny got hot the Vaseline disolved easily , grease did not , could be a urban legend
I haven't bought from 5speeds, as there has been no need, but I have visited his shop in FL. He showed me around and showed me where he used to work in design for GM for many years and has copy of the original prints.
RK
RK
Mike C.
Vaseline is a low quality mixture of oil and soft wax. It is made when raw paraffin wax is de-oiled. Grease is oil with additives to make it thick.
