67 Fan Blades and Shroud
I believe my fan blades should be 50/50 sitting in the fan shroud. My blades are all the way out of the shroud towards the driver. My corvette is running a little hot!
How do I move the blades more into the shroud? Does someone sell a spacer?
Received 2,127 Likes
What engine do you have. Without a picture I would say you have a wrong fan, and or thermostatic hub. Is there a part number (assuming it's a GM fan) on it anywhere? Is the reinforcing plate between the pulley hub and the fan? Do you know if you have the correct (all fiberglass) fan shroud? Dennis
Larry
Received 6,943 Likes
2015 C2 of Year Finalist
Received 1,857 Likes
Nope. Not if your fan blade is rearward, outside of the shroud; sounds like you have the wrong fan clutch (too short). The stock arrangement has the clutch positioning the fan so the tips of the fan blades are half-in and half-out of the rear of the fan shroud.
If they're rearward of the rear of the shroud, you'll have VERY poor cooling at idle and low speeds.
If it's "factory original" then the fan blades would be mostly inside the shroud. Something changed.
Could be the hub dimension on the water pump, the fan clutch, the fan, or perhaps even the fan shroud (replacement). Pics would be nice. Otherwise, start from the engine face and take measurements out to the WP hub, and to the fan hub. Also from the radiator back to the top edge of the fan shroud.
Have any of the water pump, fan clutch, fan, or radiator shroud been replaced??
Larry
Larry
[QUOTE=Kuhn;1590148463
Thanks[/QUOTE]
Yes. Fan spacers are available from places like Summit Racing Catalog.
Thanks[/QUOTE]
I just did this to mine today. I got longer studs and put 3 washers per stud on the water pump then installed the pulley, fan and clutch. Much improved air flow. Shemp
Do you have a reinforcement inside the pulley? If not, the three small point contact areas between the washers and the unreinforced pulley sheet metal will be subject to metal fatigue and cracking.
If you can't find one locally, try this place. Spacers available from 1/2" to 2-1/2" thick in 1/4" increments. Complete with bolts. Fits 5/8" shaft.
http://www.speedwaymotors.com/Alumin...olts,1842.html
