Carb Idle Question
Old 08-01-2015, 10:44 AM
mgistock
mgistock's Avatar
Default Carb Idle Question
I have an Edelbrock 1406 on my 62 327. After I start the engine and the choke opens, it idles about 650RPM. After driving it for 20 minutes or so, the idle increases to 1000 to 1100 RPM. The fast idle cam on the carb is not engaged. The carb was rebuilt when I got it. Any ideas? I checked and there are no vacuum leaks. I run a dual point non-vacuum distributor.
Old 08-01-2015, 10:55 AM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
Step one. Have you checked the throttle return spring? Does it have enough strength to pull the throttle back to idle position? Dennis
Old 08-01-2015, 11:14 AM
irwiny
irwiny's Avatar
I have the same issue on my 66 327 w/Holley 650 and tried the following but haven't figured why this happens with one return spring:
1) added small spacer between air cleaner and carb - no help
2) added stronger spring for secondary vacuum - no help
3) sprayed lube and cleaned the fast idle cam - no help
4) loosened the air filter nut when it was stuck high - worked sometimes
5) bought a new spring that didn't help so I used two return springs - worked the best,
Also tried to add more play to linkage didn't help.
Irwin
Old 08-01-2015, 11:34 AM
leif.anderson93
leif.anderson93's Avatar
Received 3,098 Likes on 1,866 Posts
Irwin
My '67 L79 had the same issue...this is what worked for me, as well. Bought a new OEM spring that just doesn't have enough "pull". I remove the second spring when judged.
Old 08-01-2015, 11:41 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Could be the centrifugal weights are hanging in the distributor?
Off the top of my head, the only other way for the engine to gain speed is because it's getting more air either because of whats been mentioned or you have a vacuum leak.
To Carb Idle Question
Quick Reply: Carb Idle Question
