Holley Carb Plate
Holley Carb Plate
hi guys , at one time there were stainless steel plates that you could buy that where placed under the Holley 4 barrel carberator,
one had 4 holes and the other was a big hole , who made there plates ?
are they still available and from whom ?
many thanks, grumpy
many thanks, grumpy
Received 6,943 Likes
2015 C2 of Year Finalist
Are you talking about the stock baffle. If so all the resto houses sell them
Then yes all the resto houses sell that
That Paragon one is for a cast iron manifold. I don't think GM ever installed a stainless steel baffle under a dual inlet 780 (3247?) on an aluminum manifold mid-year - did they? So you might have to substitute/modify one from a Mr. Gasket aluminum baffle kit.
there was no reason to have one on a aluminum manifold as there was no "hot slot" like a cast iron intake. but whats the difference between the two carb base plates
hi, I was at my friendly mechanics shop last week , where he showed me where a screw from the base or a Hollley unscrewed and entered the motor , it cracked a 4 block main 350 block , but it makes one think.
while playing with Holleys from 30 plus years I have never had a screw unscrew , I would like to be safe.
grumpy rob
grumpy rob
grumpy rob
grumpy rob
A Holley 4150/780 would have larger throttle bores than a 4160/600 and I assume the throttle opening in that 4160 spacer would be too small. Not insurmountable - they could be opened up to match with a drum sander on a drill.
Have you checked with Holley? You might want to go to their website.
Gary
Gary
https://www.holley.com/products/fuel...or_components/
