1963 Firewall Insulation
Happy Monday-
I want to replace my firewall insulation. It's my understanding that there is an Early and Late variation of the firewall insulation. The Late one wraps around the fuse box, and the early type does not.
Can someone tell me when GM moved to the Later variation of the insulation. My car is SN #8212.
I'm just trying to figure out which one is correct. The one installed currently is the Early style but I believe it's been replaced so I'm really not sure which one it should have.
Many thanks.
LouB
Many thanks.
LouB
Lou
This is not an answer to your question, just a heads up on the insulation install. I recently changed the firewall insulation on my '66 , when I had the heater box out and instrument cluster out. The insulation was deteriorated. To me handling the new firewall insulation was like trying to adhere Dryer Lint from your Clothes Dryer.
As you know it has to be glued in place and I couldn't wrap my head around using the 3M spray glue on firewall with my complete interior in place and the over-spray adhering to everything.
If your car is all apart then ignor this.
I had some left over Dynamat from another C7 project (I know its not insulation but thin & good sound deadening and most important more manageable to handle)
I next sprayed the dynamat foil side with 3M adhesive also the backside of firewall insulation with 3M adhesive (outside the garage) and stuck insulation to Dynamat, trimmed to shape.( Overspray still went all over thank god not inside my car or garage)
Now I peeled the back off Dynamat and installed on firewall, at least I was handling Dynamat with substance, once you touch that fuzzy firewall insulation to adhesive it is stuck and no moving it as it just tears apart, guaranteed you will not get it position right
You cannot see the Dynamat after installation and gain a little extra sound deadening not that it matters much with these cars
I would trial fit the firewall insulation first so you can see how it wraps around and mark the backside for glueing.
Good luck as this was one of my least favorite projects but this method made it managable , hope it helps
Roger
Roger
Lou
Roger
Roger
Lou
There are two different insulations being discussed here, the firewall early/late and the non backed windshield insulation which early 63 cars did not use.
My conv. is #15900 the insulation went all the way around the fuse box and does not have the upper insulation. My coupe is #15014 and does not have the upper insulation either both are May 63 cars so I don't know when they started the upper insulation, it must have been pretty late in the production.
Mark
Mark
Mark
Mark
Interesting...
Lou
Roger
Roger
I don't plan on gluing the new one in place as it seems that the fasteners are sufficient.
What is the windshield insulation mentioned? I don't have that on my car and quite frankly have never heard of that. Where exactly does this insulation go?
Thanks boys.
Lou
I removed the old firewall insulation yesterday, the insulation crumbled terribly as I removed it- there was no glue, and it appears that this may have been original insulation. The cardboard was in decent shape.
Thanks boys.
Lou
Thanks boys.
Lou
BTW 'rich5962' on here invented a slick tool for installing those pesky rubber insulation plugs -- worth looking into !
https://www.paragoncorvette.com/p-35...dener-kit.aspx
If you read post #9, it may not have been used in 1963.
