1967 L88 clone (tribute car)- Value?
Fellow forum members:
Can anyone give me their thoughts on the value of a 1967 L88 corvette Rdster that i am interested in purchasing. The owner has an absolute beautiful collection of 1967 vettes done to near perfection. This car is a frame off restoration with a 427 aluminum heads (snowflake GM authentic ) and matching intake ,etc built completely to original specs except for compression reduced from 12.5-1 to 11.75-1. It is exactly like the original inclg the 1967 oem L88 functional hood and draft tube assembly, solid lifters , radio and heater delete. Perfect in every way inclg both tops . The car has std exhaust rather than side pipes. Color is silver wit red leather int (has head restraints) and red stinger.
I appreciate any knowledgeable comments and advice.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Moving request for opinions from Cars For Sale classifieds to General discussion area.
Is it an A.O.Smth body original 427...................?
You may wish to read this thread:
https://www.corvetteforum.com/forums...-says-yes.html
What does the trim tag say?
What are the last 5 digits of the VIN?
What other documentation does the car have:
Tank sticker?
Protect O Plate?
Window sticker?
Original dealers bill of sale?
Chain of ownership/title?
Seems like a beautiful car with a great colour combo. The intake will have the "snowflake", not the heads. If the car is as good as you say, it has to be in the $80k min range. If you want to drive it, you're going to have problems finding gas to run with that compression ratio plus it'll run very hot with no radiator shroud. My kind of car though.
Hmmm, well, a NOM AOSmith body '67 427 documented partially by deduction and interpolation just sold at Barrett-Jackson for $195,000 plus a 10% buyers premium of $19,500 for a total of $214,500.
Tank sticker?
Protect O Plate?
Window sticker?
Tank sticker?
Protect O Plate?
Window sticker?
Received 6,943 Likes
2015 C2 of Year Finalist
And I think it would probably run OK on 93 Octane with the slightly lower compression and a reall L-88 cam that is going to bleed a lot of cylinder pressure off at low RPM. Some race fuel sure wouldn't hurt however. Without a shroud (easy add) or vacuum advance it will tough to keep it cool in any kind of stop and go traffic situation.
Personally, I wouldn't have a tribute car of any ilk unless I could steal it...just too dicey; unless you just love it and want to keep and drive it forever....
One-off, one-of-a-kind, hand-crafted replicas -- like Mike and Brett's Motorama Car aren't in this category of course. That's artwork, not a tribute...
Really? So you thik that if the base car had been a documentable AL Smith body 67 427 now with a NOM that wouldn't be relevant?
Wake up, Frank! B-J just proved you wrong.
The OP said it is such, so the question are relevant.
Some things other than SWCs are relevant......
Clones are really tough to value. About the only thing we can say it's worth a lot less than an NCRS/BG car. How much less it the tricky item.
While Corvettes have been flat for a while now clones are even worse off. The other problem is that there isn't a lot of upside to a clone. The big money is in provenance. With a clone you have zippo provenance.
I'm liking the $80,000 number. I really can't say it with any authority though.
Richard Newton
A Collection Guide
Richard Newton
A Collection Guide
I think it's value is about $10 - 15K over what ever value it has as a NOM BB restored car with a period correct motor and otherwise correct restoration as evidenced by some documentation paperwork and/or documentation from the restoration.
However if it goes to Barrett Jackson then the stupid money factor will probably drive it up another $50K on top of that.
What would it cost to make one?
For instance, I have a NOM SB 67 Vert. What would it cost me to make a tribute L88? I paid $40K for the car, how much more would I need to put in it to get to L88 status. Not trying to fool anyone...
20K for the motor?
and what else?
20K for the motor?
and what else?
I'm sure I'm missing a few things.
