Accelerator Pedal Linkage
Gentlemen
I still have an occasional sticky throttle on my 66 and am contemplating replacing the nylon bushings [9] in the throttle linkage.
I had the ignition shield off today and access looks very limited in there to access the 2 bolts that hold the support flange to the transmission/firewall tunnel. Has anyone replaced this with the engine in the car? Looks like I will have to remove the distributor and oil line to get access to those bolts.
Randy
Randy
Received 2,127 Likes
I may be wrong, but I think you only need to loosen the lever shaft retainer nut, then slide the rod out from inside. Clean up everything, replace the bushings, lube and carefully reassemble...after expressing your displeasure of needing to do the job. Having said all that have you tried lubing things as much as possible? Dennis
I'm sure you've already checked it out but its real easy for that footwell downroad to ride off the nylon piece on the back of the pedal and snag up on the rubber ridge on the side surrounding it. I had that happen in my '63 with a repro pedal...
FTF yes I have checked the curved portion of the rod and that is centered on the nylon pad thru the pedal travel. I have checked the linkage with a mirror and no apparent binding at air cleaner or other spots.
Road test tomorrow
Randy
Gentlemen
Randy
Randy
Jax
Jax
