Intake Manifold Contradicting Numbers
3rd Gear
I have a 1965 convertible with the original numbers matching 300 hp 327, I was looking into the carburetor because it is a holley and i know the 65 300 hp came with a carter afb. In my inquiry to why it has a holley I looked up the intake manifold numbers 3872783 and the numbers indicate that it is a 1966 300hp intake but the date stamped A 8 5 indicates it is made january 1965, much too early for the serial code to say its a 1966. I have attached photos of the casting numbers and if anyone knows about this I would love to know what is up with these numbers.
Interesting question. Colvin's "Corvette by the Numbers" says it's for 1966 and 67 327/300 hp applications, but that it was also used extensively as a service replacement.
I think that may be what the "2" below your casting number indicates.
Perhaps your car had a replacement intake manifold at some point?
Edit - the reference also says it accepted either a Carter or Holley depending on the application.
Edit #2 - the '65 327/300 hp came originally with a 3844459 intake and a Carter carb. I think somebody back when wanted a Holley carb on that car and changed out both the intake and carb to make that happen.
3rd Gear
It does sound like someone replaced the intake and carb along the way. A lot of years have passed since 1965. By the way, welcome to the Corvette Forum, how about posting up some pics of your Glen Green 65 Roadster?
Mike T - Prescott AZ
3rd Gear
I understand that the carb and intake are not correct originals but its still unclear why the 1966 intake manifold is date stamped with a January 1965 date and why does it have the big H on it
H is for the Holley application?
My 65 Roadster has the exact manifold and Holley carb as well
My 65 corvette roadster has the same manifold and Holley carburetor. I was also wondering whether someone swapped them, is it possible Chevrolet configured them this way?
Just another Corvette guy
And what is the date on your intake manifold Roger?
BINGO! you got it.
