C1 power steering
C1 power steering
I would like to add power steering to my 57 that I have owned and really driven for 20+ years. Just want to add power steering not change to rack and pinion etc! Would like to buy a complete kit (not Dave Cranes) or if someone has pieced one together would like to know what parts you used? Again: I don't want to go the rack and pinion route, as I rebuilt my steering box many years ago and it works great ... just tired of hoarsing car around to park it. John
This is how I did it. This system works perfect in a C1. I've been
using it for a few years now. Total cost was around $600.
I am using a 13-14 inch steering wheel. You can park it with one
finger.
Be sure to read the parts list up front.
Raay
Here is another (pricey) idea...you'll have to search for the web site - I'm not allowed to post it here:
http://www.superchevy.com/how-to/pro...pgrade-part-2/
I wonder if it would still serve as a death spear in the event of an accident, as it doesn't look very collapsible.
That is going to be hard to do, since the steering shaft is attached to the worm gear in the steering box on one end, and the steering wheel at the other.
The electric unit that Frankie posted still requires that the shaft and tube (that is press fit into the box casting) be cut (so that the electric power "adapter" is spliced in between both ends).
Most guys want to get rid of the existing steering box, since they "do" wear out, and then have a difficult time replacing the gears (perfect gear replacements are not "exact", if even still available). And frankly, the box is where a portion of the "steering effort" is going. A rack & pinion is a lot more precise, and may not even need power (depending on your requirements).
Good luck,
Plasticman
I rebuilt my 57's steering box many years ago when parts were available! I can't bring myself to cut the steering shaft for rack and pinion. If I was going to go that direction, I would use a Myers front end setup, but why stop there, I might as well get a Newman type frame etc and it goes on and on.
I came across a guy that actually had his mechanic install a David Crane PS unit on his C1 ... he has no idea what he has but I took a few pictures. His only complaint is the lack of turn radius i.e. rack and pinion problem.
Wondering if someone knows where Crane gets his kit?
Any help appreciated, John
ABS Power Brake has on their website (click page 56 on the link below) a "Quick Ratio 1953-62 Power Steering Kit." However, I've never heard or seen any posts on anyone actually buying or installing this kit. Also, their catalog hasn't been updated in 6 years:
http://abspowerbrake.com/maincatalog_frameset.html
This may be the same setup from another vendor:
https://www.corvettebrakeparts.com/p...l.asp?prod=594
I saw a video from Crane on that steering "system" in 2005. It looked very cobbled together and leaked in several places.
In other words, it was a good way to "steer" me away from it.
Plasticman
You have to get used to always having the car moving when you turn the wheel. my grandmother could drive ms trucks in the 60's. we have just all become spoiled. I LOVE MY POWER RACK AND PINION. many times the steering gear is toast, regardless of whomever says they rebuilt it.
Premium Supporting Vendor
C1 Steeroids
