Dumb idea or...................not?
As some of you may remember, I'm in the process of having my 1967 chassis rebuilt. New frame and suspension from Vette Products and checked over original engine. Probably going to have 25-30 K in it when done. Hoping the value of the car will go up accordingly. Also looking forward to driving it again and listening to that engine run up to redline (or near readline) through the side exhausts.
I was reading the current thread about upgrading a small block car to a 396 or other BB. Got me to thinking. Blowing up the original engine would probably reduce the value of the car $50,000 or more.
Maybe, I should just put in a rebuilt 454 (or ?) with the 3x2 manifold and store the original engine. Sounds like that can be done for $5-6,000.
Would that be a smart thing to do???
If you don't plan on abusing the original drivetrain when the car is complete and driveable, there is zero reason to "bag" the original engine. These cars are pretty bullet proof if driven in a reasonable fashion and serviced on a regular basis. Save the money for the 454 and enjoy your fabulous car
Gary
I run both original engines in my '61 and '63...you can have plenty of fun in these cars without running them to redline. The rev limiter on my '61 is set at 5800 RPM and on the '63 at 4800 RPM (Pertronix ignitions). The former is a solid lifter motor and the later a base 250 hp motor....
Quote,
"Blowing up the original engine would probably reduce the value of the car $50,000 or more."
It would like to find the guy who would want to spend $50,000 for the original engine!
I have this bridge in Brooklyn...
Not talking about the price of the engine, but the price difference between a car with a genuine L71 and one without the original engine.
How hard are you planning on driving it? Unless you plan on racing it and totally abusing it to the point of 7000 rpm "hand gernade" failures with pistons blowing off heads and rods through the block, any engine failure should be repairable for far less than $50k, thus retaining the original engine.
Cylinders can be sleeved, blocks and heads can be welded and refinished, etc.
I'm not sure I understand what you are so worried about? You can always repair the engine for far less than your thresh hold value of perceived monetary loss.
1967 coupe, 427/435hp, 3.36 rear, marlboro marron, saddle interior, side exhausts, PS and PB. My first new car and the best $4,550 I ever spent
He's going to tell his wife that this is what all the gurus suggested that he do with the engine.
Richard Newton
Richard Newton
If more power is the objective - go 496 or somewhere up around 540. That would be fun but probably not going to happen for around $6,000.
