Front end alignment on C1
Received 1,126 Likes
When I pulled my cross-member the tapered shims where missing. This produces extra positive caster.
Unless the spindle is bent or you have worn components you should have enough adjustment on the upper eccentric to bring the front end into spec.
Joe
Tom would have more knowledge than me on this subject but I did rebuild my front end on my 61 and I so my own alignments.
Joe
Joe
Thanks again
Are you having trouble getting camber or caster or both?
Joe
http://www.ebay.com/itm/1956-62-Corvette-front-crossmember-to-frame-aluminum-shims-/331642417641?hash=item4d376db1e9&vxp=mtr
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Your '60 would have come from the factory with 2 degree shims installed between frame and crossmember. Are these no longer present?
C1 front end alignment
The shims go between the cross-member and the chassis. You would have to remove all the bolts and drop it down enough to slip them in.
Joe
http://www.ebay.com/itm/1956-62-Corv...6db1e9&vxp=mtr
Joe
I will have to check to see if the shims are in. #2 The front end man said his research showed both the camber and caster were controlled by the eccentric. When rotating the eccentric we got almost NO improvement. Are the two separated as opposed to what he was able to find online?
Thanks guys.
The alignment sequence is to, first, turn the eccentric as many turns as needed to get the caster dialed in. Then make one final rotation of 1/2 turn (or less) to dial in the camber. If your alignment guy can not measure ANY change in either caster or camber, then something is wrong with the eccentric mechanism.
And to answer your other question, the aluminum shims between frame and crossmember add 2 degrees of positive caster. You really want to verify these shims are present before trying to get caster dialed in with the eccentric.
Jim
This is the right upper outer eccentric. Notice how close the spindle is to the rear of the upper A frame, maximum + caster. When you turn the eccentric the upper arm will move forward and rearward to increase or decrease caster and also move the spindle in and out to adjust the camber. Have your alignment guy turn the eccentric to see if the arm is moving properly.
As Jim has stated, do the caster first and then the camber.
Have your guy check the front end really good looking for worn parts.
My 61 had extremely worn upper A bushings and arms. I had to replace both upper arms and all steel bushings. She pictures.
Joe
The upper arms were so worn the steel bushing were loose in the arms.
Here is the lower outer bushing and bolt:
Joe
Received 3,443 Likes
Question: do you loosen the clamp bolt before you attempt to turn the eccentric bolt? My ST12 manual shows the removal of the actual grease fitting, and says there is access to the shaft internally.....from what I'm seeing, it looks like you simply loosen the clamp, and turn the big hex heads that the grease fittings are screwed into?
hi mr GTO, no you remove the rear grease fitting and insert a L hex wrench to turn the upper eccentric bolt, will try to take a picture later today, grumpy
o
o
You MUST loosen the clamp bolt, in order to turn the allen head eccentric!
The Allen head wrench is 1/4" and fits through the rear upper (outer) grease fitting hole (after the Zerk grease fitting has been removed).
Note that someone on my 62, had previously redone the front end, and installed the eccentric's Allen head socket end on the passenger side on the front of the shaft......
and yes, they put a grease fitting cap on that end too (bless em)....I just had to find it!
Plasticman
Plasticman
Thanks, guys....working on this front end reminds my of the '37 Chrysler I used to own....except the '37 was much more modern and conventional in its design!!!
Dave Z
P.S. Tom and I did these a while back. He did all the "heavy lifting", I just pulled the documents together.
