Most important item corrected using the forum.
I have to say .
Installing KOs the correct way and knowing the difference when installed correctly '
New circuit for headlights dedicated to Battery.
Engine break in Procedures for cam.
Overheating problems rank high on list
and so many others as member's looked at pictures helping me
get parts and trim ,doors installed correctly. These are just a few.
I think the most important item I learned off the forum is the headlight motor replacement/rebuild information. That was an eye opener for me as I couldn't see a thing without the mirror trick. Last year my right headlight would not come up or go down, checked the forum and it was a faulty ground, problem solved. Get the car out of storage this year and the right headlight won't go up or down, checked the forum and it was the connection at the bulkhead, one of the pins had become detached in the connector, problem solved. This forum has save me a lot of grief and a ton of money. Thank you C.F.
