hood repair
hood repair
One of the four hinge holes on the passenger side of my 65 hood has a stripped thread. What is the best way to repair this problem?
I'm almost hesitant to weight in on this - the plate inside the hood is not very thick I don't think. You could try thread repair kit (Helicoil) and coat it with epoxy to help anchor it, before running it into the over-drilled & tapped hole. Another thought is a nutsert which I think could work. Just have to be real careful overdrilling the hole out.
http://avdelusallc.com/products/nutsert.shtml
If not overly concerned about appearances you might be able to tap the hole for the next marginally larger metric bolt - an option, but not one most would use.
There are thread repair epoxies out there but I just can't believe they would work and hold up.
I think another name for these is riv-nuts if you decide to look into them.
