Restoring rusty original exhaust manifolds on C2
There is a YouTube video in which a guy soaked some old rusted metal in vinegar for a few hours as an experiment. The results looked remarkable, as it removed all of the rust down to bare metal. Has anyone used vinegar to remove rust & corrosion from d exhaust manifolds? I was planning to bead blast mine, but wonder if this might be an even simpler way to do the job. Thanks.
Haven`t used vinagar, I use the works toilet bowl cleaner . Let it sit overnight, making sure all the air pockets are filled inside, flush with water and baking soda, ready for high heat paint.
Tony
Tony
Personally I would bead or sand blast them then use POR-15.
Gary
Gary
Received 6,943 Likes
2015 C2 of Year Finalist
Not as simple as that.
First you have to clean off all grease, oil, etc. Mix white vinegar, lemon juice, some other stuff. Time soaked is very important. There'll be a darker tone you'll have to watch for. Then you have to neutralize the acid from the treatment and wash it clean. The treat it so it doesn't flash rust.
Try on something small first.
Sand blasting slightly alters the surface and rounds out details, numbers. Maybe not enough for some, but I wouldnt go that route unless you do it lightly.
Had my manifolds ceramic coated, in the process of which they heat the metal to very high temps, which gets rid of any oils, etc. I'm not sure if this would get rid of rust also. Ceramic seems to be the most durable coating for manifolds.
[QUOTE=LouieM;1590541240]Had my manifolds ceramic coated, in the process of which they heat the metal to very high temps, which gets rid of any oils, etc. I'm not sure if this would get rid of rust also. Ceramic seems to be the most durable coating for manifolds.[/QUOTi like many have used white vinager and have had good results it may take a few days but it does work
I sand blasted mine and used high temp paint from Ace Hardware store.
I baked them in my oven at 200 degrees and let them cool, followed by two more heating's at 300 and 425.
The paint has protected them for over a year so far without and discolorations.
Mine are also ceramic coated, and this process will get rid of the rust if their not deteriorated.
