Small Block Numbers Info Needed
Looking for info on a small block 350 cu in engine in the '66 Vette I'm currently driving. I purchased the engine rebuilt from Conlee Rebuilding service in Memphis back in 1993. It's supposed to have hyper eutectic pistons and a Comp cam, as I recall.
The photo below is the only readily visible number I see, but should be enough to identify the engine, I think. I'm interpreting the number to be T0626CMJ, and am guessing based on my limited knowledge that it's probably a Tonowanda engine built June 26, and the last three I'm guessing to be C?MJ. I thought the CMJ would translate to a 1974 police engine, but there are guys out there a lot more knowledgeable than I
I apologize for the upside down, but I've put this in right side up and upside down both, and it insists on making them all upside down . . . . I'll figure that out later . . . . .
My real question is in relation to upgrades for this engine. I'm planning on replacing the heads with Summit Racing® Cast Iron Cylinder Heads for Small Chevy SUM-152123, and am wondering if I can use the old Edelbrock C4B aluminum intake (has the oil fill tube going into the engine block) with this combination, or if I'll have to go to a later intake manifold. I also plan on sticking with the original cast iron exhaust manifolds, no headers.
Advice and suggestions appreciated, just want a good daily driver with minimual $ outlay on my part.
Thanks!!
Thanks!!
CMJ was also used in 1980 for a 305, need the casting number. This link may help you in finding it
http://www.mortec.com/location.htm
Received 2,127 Likes
If you can post the casting number from the back of the block, it would help. I did find CMJ as a 305, 1980 Camaro and 1974 350 police. Dennis
Accepting as fact that it's a 350, how does that leave the answer to my question regarding the C4B intake, etc.?
Received 1,857 Likes
Any small-block externals will bolt up to just about any block with no issues (until you get to the really late Vortec stuff when they started changing bolt hole directions and locations); prior to that, "anything pretty much works with anything".
Received 6,943 Likes
2015 C2 of Year Finalist
By 1980 didn't the stamp pads get smaller?
I thought I remembered something about the later model 350's not having provisions for the oil filler tube or for the crankcase pcv return in the block, am I remembering correctly? The C4B manifold has provisions/allowances for both, will the 350 block accommodate these?
I suppose one might drill a later model block at the proper location at the rear to accommodate the PCV line, but I'm not going there . . . . .
