Q re 1967 327/350 block 3892657
Old 10-03-2015, 01:30 PM
bob-vette
bob-vette's Avatar
Default Q re 1967 327/350 block 3892657
Is it correct for 1967 327/350 block 3892657 made in Flint "V" code to have this threaded outlet on the right front of the block about 1 inch below where the oil filler in the intake would be? See photo, thanks.
Old 10-03-2015, 04:50 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
yes. only flint casting had that. and only flint cast small blocks went into Corvettes
bob-vette (10-07-2015)
Old 10-04-2015, 03:25 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
I think a few Tonawanda cast blocks (3858180) went into a limited number of Corvettes back in 1965...............however, all the Corvette small block engines were machined and built at Flint.
This is per the NCRS 1965 Judging Manual, Fifth Edition (purple cover). Page 82.
Larry
Old 10-07-2015, 01:12 PM
bob-vette
bob-vette's Avatar
What was this threaded outlet used for?
thanks for the info.
Old 10-07-2015, 01:13 PM
bob-vette
bob-vette's Avatar
thanks for the info
Old 10-07-2015, 05:07 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
It was part of the machining process to create an internal intersection at the front of the main oil gallery; The Tonawanda machining process was slightly different and didn't require the external hole.
To Q re 1967 327/350 block 3892657
Quick Reply: Q re 1967 327/350 block 3892657
