58 - Not enough lip on stainless molding for T-bolt to grab
Old 10-07-2015, 03:30 PM
jusplainwacky
jusplainwacky's Avatar
Default 58 - Not enough lip on stainless molding for T-bolt to grab
Hello -
How many times have you gone to put a T-Bolt on your side molding only to find out there isn't enough "lip" for it to grab at the ends?
One method is to epoxy the t-bolt into place, but personally I don't trust epoxy adhering to stainless when there is stress on the part.
So, here is my fix...What I did was cut a piece of metal (just happen to have an old electrical box) that has the same thickness and I welded it on, making an extension. I also had to put a slight arch in the metal to follow the curve of the original T-bolt. I have piece of mind that this isn't going anywhere.
Old 10-07-2015, 04:33 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
That certainly will work.
is that repop molding?
i never had problem with t-bolts with my original moldings (which i had the dings removed from, polished and flash chromed).
Doug
Old 10-07-2015, 04:37 PM
jusplainwacky
I don't know if it's repro.
Old 10-07-2015, 05:00 PM
jasonsamara
jasonsamara's Avatar
When I took mine apart I found this fix on my car behind most of my stainless around the waterfall, back of seats. I thought to myself why would someone not just purchase repop parts? Then I found out they are not cheap for a set of them.
Old 10-07-2015, 05:05 PM
jusplainwacky
What was "the fix"? Same thing I came up with?
To 58 - Not enough lip on stainless molding for T-bolt to grab
Quick Reply: 58 - Not enough lip on stainless molding for T-bolt to grab
