Save on Race Ramps Flatstoppers at Zip
Platinum Supporting Vendor
For a limited time, you can receive a $25 mail-in rebate when you purchase a set of Race Ramps 14" Flatstoppers.
Flatstoppers keep your Corvette's tires from flat spotting during long periods of storage. Flat spots are particularly troublesome for collectors using bias ply tires. Once the tires are set in the Flatstoppers (on a level surface), they will settle into the pad's concave depression. The bottom portion of the tire will be fully supported, thus dispersing the weight of the car more evenly onto the tire and helping to prevent any tire flattening.
Designed to cradle your tires in their own radius, conforming to your tires, Flatstoppers do not conduct heat or cold from changing floor temperatures. Will not damage your hot asphalt, cement, or painted floors.
Flatstoppers are made with patented super-lightweight 100% solid construction technique – making them highly durable and virtually indestructible while providing a 6,000 lb. vehicle weight capacity. FlatStoppers' textured coating prevents sliding across floors - including epoxy-coated floors.
Measures 22.3" long, 3.5" high, 14" wide. Will accommodate tires up to 12" wide and 25" to 30" in diameter. Sold as a car set.
Don't delay! Get your mail-in rebate form here. Offer ends Dec. 31, 2015.
