T-10 Tranny guru's need advice
Old 10-14-2015, 02:46 PM
devildog
Support Corvetteforum!
devildog's Avatar
Location: fighter pilots make movies, bomber pilots make history
Default T-10 Tranny guru's need advice
Guru's thanks in advance
I have a T-10 I took out of my 61 some years (installed T-45, love it!). I have a 63 Avanti with a bad 3 speed (Stude used a T10 in the 4-speed Avanti). I am thinking of putting the T-10 in the Avanti.
My T-10 numbers:
T10-1B cast
W.G. Div.
01 stamped
1-27-0 small screw mounted plate
T10-7B cast on Al tail
9-19-60 small screw mounted plate
The Avanti manual T-10 is listed as a AS6-T019D
1.My T-10 was functioning great, I rebuilt it in about 1973 and has run 100,000+ miles (should be rebuilt before installed)
Suggest its value...I have no idea?
2.Is my T10-1B similar enough to physically substitute for a AS6-T-10D in the Avanti? I realize shaft and tail splines maybe different
Thanks again
Joe
Old 10-14-2015, 03:05 PM
desertpilgrim
desertpilgrim's Avatar
What is the stamping on the driver's side rear main case?
Old 10-14-2015, 03:06 PM
domenic tallarita
domenic tallarita's Avatar
I have a T-10 I took out of my 61 some years (installed T-45, love it!). I have a 63 Avanti with a bad 3 speed (Stude used a T10 in the Avanti). I am thinking of putting the T-10 in the Avanti.
My T-10 numbers:
T10-1B cast
W.G. Div.
01 stamped
Thanks again
Joe
Joe,
I remember rebuilding them way back then and am almost sure that the tail housing and splines were the same.
Dom
Old 10-14-2015, 04:13 PM
devildog
devildog's Avatar
Thanks for response. I see a hand stamp (maybe gang stamp)
WK1702
does that make sense
thanks again
Joe
Old 10-14-2015, 10:23 PM
tuxnharley
tuxnharley's Avatar
Received 1,939 Likes on 1,185 Posts
You've got a 2nd design Borg Warner T10 with a cast iron main case and tail housing (about 15 pounds heavier than the 3rd design with aluminum cases).
W = Warner gear
K = November
17 = 17th
0 = 1960
2 = 2nd shift
To T-10 Tranny guru's need advice
Quick Reply: T-10 Tranny guru's need advice
