65 Steering column removal
Old 10-23-2015, 07:38 PM
mazlen
1st Gear
mazlen's Avatar
Default 65 Steering column removal
I am trying to remove my steering column on my 65 to rebuild the clutch linkage
Old 10-23-2015, 07:43 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,943 Likes on 4,782 Posts
2015 C2 of Year Finalist
Why do you need to remove the column to get to the clutch linkage? Seems more work then needed. But it's simple to remove. Unbolt the rag joint the undo the clamp and bracket on firewall. Then inside disconnect the wiring harnes then unbolt the column supports and the part on the dash cluster. Then pull straight out
Old 10-23-2015, 07:48 PM
Vet65te
Vet65te's Avatar
Received 1,032 Likes on 671 Posts
Mazlen - I see this is your first post, welcome to the Corvette Forum.
When you say 'clutch linkage' do you mean the pedal assembly? If so, I've heard some guys have figured out how to get it out without removing the column but I never could figure it out so...out came the column. Nowhere Man has already given you some tips on getting the column out. Also, since it's going to be out, if you 'ever' had an inclination to refresh your instrument cluster (bulbs, lenses, gauge faces, gauges themselves) this would be the perfect time to pop it loose since all the hard stuff would be out of the way. Post up some pics of your 65 when you get the chance.
Mike T - Prescott AZ
Old 10-23-2015, 08:50 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
A second welcome to you. In order to help yourself, get a Chassis Service Manual. Available via many of the supporting CF vendors. Dennis
To 65 Steering column removal
Quick Reply: 65 Steering column removal
