L71 distributor specs
My engine is being set up for a dyno check run this week. As wiring the TI distributor and module to work might be a problem without a wiring harness (staying on the car), the engine builder is going to just use a Chevy HEI distributor. I know that the initial timing is supposed to be 4 degrees BTC, but what should the max centrifugal advance be?
Usually total timing (initial and centrifugal but not vacuum) is targeted for around 36 degrees on generally stock engines. Some engines might tolerate a bit more and some may prefer a degree or two less. IMO it's not going to be very responsive for street driving if your distributor curve will only allow 4 degrees initial timing. I have mine set up for 12 degrees initial timing and 24 degrees centrifugal but it's also not stock. Unless they are going to dig into the distributor the safest thing is to power time it to 36 degrees total and let the initial timing fall where ever it falls for now.
Don't think you will need vacuum advance for a dyno/break-in run. Normally the RPMs are above 2000 RPM and often the carb is at WOT.
Larry
