Any suggestions on keep rust of metal?
My hood latches keep rusting up...is there anything I can put on them that can keep the rust off? I prefer not to paint them.
Thin coat of vaseline or oil...both will collect dust..
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
You could have them re-plated with either cad or zinc. That will keep the rust at bay.
I am not a keeping the Vette looking perfect type of guy
but in the hobby car miniature world, they have high end spray paints (testors, gunze, tamiya are some brands), and cans of flat, semi-gloss, and clear high gloss and I have bought both lacquers and enamels.
Damn the pretty car group should give me a metal, for such a helpful idea!
I used rattle can flat clear on my front sway bar after I removed the paint someone had applied to it. It was for judging, so I sprayed flat clear on the sway bar to prevent it from rusting. That was years ago and not a lick of rust on it. With flat, you won't even be able to tell there is an applied finish on the item, and can removed with thinner if desired. ARA
Rustolium has a clear coat that is for garden tools like shovels and I just bought a can to try. So far I like it but have not checked the gloss level. I looks glossy and stays wet for a loooong time to soak in. When it dried it was rock hard.
All my cad plating is starting to look shabby and I'm not finished with my vette.
I am going to try it today over some cad because of this thread.
Dom
Dom
Location: Las Vegas - Just stop perpetuating myths please.
Try some gun steel blueing chemicals. U can buy them for browning instead if u like. Pretty simple stuff to use but do use chem resistant gloves. I recall u need to do some scrubbing to prep the steel then can apply several different ways and finish by stabilizing with plane water. Unless u touch it with sharp objects it should stay as is.
What i did to my hinges on my C3 is paint them. But i used the "hammered" silver rattle can enamel then baked it on at 250* F in a little broiler oven. I like it. Hey its a non collectible C3 and i cant hurt the valve at all.
Hope this can help.
Hope this can help.
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Hope this can help.
Hope this can help.
Thanks everyone!! Some great ideas!
