My 1961 Complete Rewire in one thread
Nice job on the PDFs Dave. I wouldn't even start this job without the Dr. Rebuild color pictorial schematics. They have the GM wiring schematic errors corrected and the connections have been checked on real cars. One of my better investments on both the C1 and C2...
Dave Z
First Power Up
YES. It's taken way too long but with family things settled down I can now get focused back on the car. This is the configuration for the first power up. I checked the ohms on every circuit which turned out to be a good idea since I had two pink wires on the ignition switch reversed. The fuel and temp gauges also cause an unexpected 62 ohms to ground reading but that's explainable after checking the wiring diagram closely.
After I get the 609 water pump, ribbed hoses, and the cut down upper motor mount cushion installed I'll get back to the electrical.
I know this is an old post...but anyone have some pictures of what the wiring looks like under the dash...how it routes from one side to the other? I'm referring to a 56-62.
The assembly manual sucks.
Excellent!
LOL...not sure what is "Excellent".
This is pretty hard to see... but I'm holding the courtesy light wire with a ground. Does this harness run between the fiberglass and the metal support? And where does this ground connect to?
In my assembly manual it's really not clear.
Well....when it comes to how the wires route, some diagrans are pretty good, but in other area's it's hard to see what the heck is drawn.
Cool thread John.
I'm just about complete after installing the LL wire harness package into my '62.
I'm to the point that I need to convert the standard engine harness over to single point alternator, and integrate an ignition system.
I do have to say that the Lectric Limited has worked out very well for me.
I'll keep watching!
Pat
I'll keep watching!
Pat
I did the same job on my 1961 and now I am also at the point to convert the standard engine harness over to single point alternator with MSD ignition system.
Do you have any advice on what I have to change on the engine harness? The very long red wire goes to the one point alternator? Also witch wires are connected to the regulator... and solenoid(Starter)?
There is a red wire on the MSD meant to go on the ignition switch, on witch wire it is attached?
Any help, images or pdf will be very welcome
Thank you,
Ferry
#33
Due to circumstances I haven't been able to focus hardly any time on the rewire but things are better now. I've looked at the dash underside in a number of late C1s and there isn't anyone that looks factory so far. I have a factory AIM and even it's a little short on specifics. I'm doing some rerouting to get the engine wiring and tach cable right up underneath the windshield mounting holes - I made my own J clips. Lots of cars have the wiring and tach cable so close to the windshield wiper cable it's scary since this looks like a really good "saw".
#34
Dave
Thank you for posting the PDF files,,,, i just did my new harness and your cluster wiring pics helped me a lot
#35
solidaxel (07-11-2018)
#40
I have completed many autowire kits and this is the first time I used a "factory harness"
other than the price this job was one of the easiest and fastest I have ever completed
Thanks for the PDF it was nice to have a colored pic for a reference
........now where does the light on the side of lighter get its power?
