Transmission yoke length?
Old 11-15-2015, 11:24 PM
Tracy64
Tracy64's Avatar
Default Transmission yoke length?
Hey guys,
Quick question or three. Can anyone tell me the length of the drive shaft yoke that goes into a manual transmission of a '64 and the length of the section the slips into the housing? Also, how far should the yoke slip into the tail shaft housing? I have a little movement in mine but if I disconnect the drive shaft and move the yoke about 1/2 inch into the housing the movement is greatly reduced. Just curious if the yoke is wrong. I believe the drive shaft is the correct length, 30" centered on the u-joint caps? Thanks for any info offered.
/Tracy
Old 11-16-2015, 10:09 AM
Donald #31176
Donald #31176's Avatar
Corvette yokes spline section are approximately 4 3/4 inches long and passenger yokes lengths are 3 1/2 inches long.
Old 11-16-2015, 11:36 AM
domenic tallarita
domenic tallarita's Avatar
Tracy,
that is a symptom of wear on the yoke in the area that rides on the trans bushing.
I had mine metalized and ground back to size.
Dom
Old 11-16-2015, 07:16 PM
Tracy64
Tracy64's Avatar
Thanks for the info! I'll check those things.
/Tracy
To Transmission yoke length?
Quick Reply: Transmission yoke length?
