Small leak in radiator-1958
My 58 has the original Harrison radiator that surprisingly keeps the engine very cool. I have a couple very small pinhole leaks that weep coolant and drip down and collect on the lower fan shield. It's never a large amount of coolant but I'd like to somehow fix it. I've tried a skim coat of JBWeld on a couple occasions but that doesn't last. Any ideas, like pepper or Bar Leaks? I know at some point I'll replace it with a DeWitts but is there any decent fix that I can implement for now?
I am not a fan of stop leak products. If it goes into your radiator it will also go into your engine block and I don't want anything but coolant in my engine block. Pull it out and take it to a radiator shop to have the core cleaned and repaired. You will probably find several more pin holes when they clean it.
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Received 1,946 Likes
It's 57 years old! Consider it a blessing it lasted this long. If you plan on replacing with a DeWitts anyway, why not just do it now and then you won't have to worry about it.
Some say our aluminum Harrison's can't be repaired???
Jim
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
The one and only time a mechanic added stop leak (without my knowledge) to the brass radiator of one of my cars, it plugged up enough of the radiator that the engine started running hot. There were areas near the top of the radiator which remained stone cold.
Take the radiator to a competent repair shop and have it fixed. You'll be good to go for a long time.
Jim
