1965 Vette build
1965 Vette build
I'm putting my 65 Vette back on the road after it was hit by a hit and run driver . The frame was bent enough I didn't want to try and have it straightened. So after lots of pondering I decided to use a C3 frame to start my reincarnation . I bought this car with the intention of building a resto mod for road trips .
So for all you purist now might be a good time to hit the back button before you are beside yourself with the abomination that is about to take place .
So let's start with the car several months ago .
As you can see it was a flared car that was far from original but I liked the car none the less . This project will be built with that fallowing .
VanSteel coil over suspension and borgwarner power steering , thanks Dan .
TKO 600 conversion with upgraded syncros , thanks Ken
Wilwood brake upgrade calipers master cylinder .
Be cool radiator and spall fan
Flares by Jeff Freeman along with front spoiler .
Front nose by JD corvette
weld 17" wheels
And the list goes on , I will post pics of the build as I can and will post a detailed description of the C3 swap .
Thanks Ed
weld 17" wheels
Thanks Ed
Enjoy while you can.
Received 2,684 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Go for it
Why not use a proper C2 reproduction frame? You may still run into problems with modifying an old C3 frame to fit - could be bent, could be rusty inside, etc. Also, it seems I remember that sometime during the production run of C3s they went to thinner frame material - probably in the very late 70s - maybe about the time they went to the bridge differential support. I would avoid those.
Look forward to seeing it back on the road. Good luck.
Knowing that you were planning on a 'resto-mod' as you put it...which I am ALL for it!
And I am sure you considered this...but in the case you might not have...I would look a the frame when you get it out and send it out and get the C4 front section welded to it. BUT...that all depends of you want the aluminum control arms, etc and have the provision for a rack and pinion, transverse leaf spring if you want it already for you to install. I am not there with gauges measuring out your frame...but from what I can see from the angle of the photo you posted....and know about frame straightening....this frame can be used..and have a front section sectioned in....but that is unless there is some serious kinking of rails that I obviously can not see.
Just a thought.
Sounds like a great project!
DUB
Just a thought.
DUB
Whatif (11-25-2015)
The frame swap is easy but there is nothing about the mounts between a C2 and a C3 that is anywhere near the same .but if you have both frames next to each other it's a straight forward job.
Ed
Just a thought.
DUB
Just a thought.
DUB
I thought about the C4 stuff but in the end went with VanSteel suspension . The frame is pretty bad and I thought about sectioning it but found signs of a past accident and poor repairs and opt to just start with a known good frame . I finished the rear section and it turned out pretty nice .
Ed
I will do a write up on the frame swap when I get my photos in order but you can get an idea of how I used the jig to hold everything square and eliminating the need to worry about getting things out of whack . Here is a quick look at how the finished product looks.
Ed
Ed
And no insult intended over the use of "proper" frame. It's just a bunch of work to convert due to the mounts, front stub outs and rear frame member - but you look up to the chore. I think (not sure) that a 77 frame would be before I understood that they thinned out the frame metal. Good luck.
By NO MEANS am I passing any judgements on what you choose to do. I was just 'throwing' options out there...if you were not aware of them. I would hate that down the road....you found out about a 84-96 front end conversion and then felt like crap because that IS what you wanted to do....and then...I would feel like crap because I did not mention it.
It surely looks like this is NOT your first 'rodeo'. I am sure you are covering all the 'bases' and taking 'things' into account when you go and weld it up....so.... no need for me to spout off 'stuff'.
Looks good and keep up the good work...from what I see...all is GOOD!
DUB
DUB
Whatif (11-25-2015)
DUB
DUB
I appreciate all info and please keep the suggestions coming . Sorry if I posted like I didn't appreciate your input because I do , as this is my first Vette build and am a newbe here .
Thanks for taking the time to look over my thread and keep the Comments coming .
Happy Thanksgiving
Ed
