...any "good" experience with exhaust wrap?
#41
Question: when wrapping the exhaust pipes, does one have to wear long sleeves and gloves to avoid the "fiberglas itchies"? Is the titanium wrap basically fiberglas?
I don't quite understand what the silicone spray coating is supposed to do. It's silicone as in *****, not silicon as in lubricant, so does it harden into some kind of rubbery coating that protects the wrap material?
The Titanium wrap is made from lava rock..better explained in this link...which is supposedly easier to install, and requires no silicone spray unless you want to spray the pipes first. (....it says "do not spray the Titanium wrap" in the installation instructions).
Also the Titanium wrap does not need wetting prior to installation...and is more stretchy/flexible and easier to wrap tightly. (...it supposedly has a similar appearance to carbon fiber, as per the link too).
https://www.designengineering.com//c...-lr-technology
There is quite a bit of information about the products and installation tips on DEI website with the products.
#42
Silicone as used to manufacture intercooler hoses, etc, (I'm guessing?)....it applies like spray paint in the installation videos for the fiberglass wrap. It's purpose is to lay down loose fibers/hairs and seal the fiberglass wrap. I can see changing the wrap color might be nice in some applications...comes in black, aluminum and white...and appears to cover well in the video. Color changes are not an option with the LR Titanium wrap...only the fiberglass type.
#43
Yep ..me too. Worm gear clamps will work better... and are waaay cheaper than theirs!
#44
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The wrap has stood up well overall. Only issue I've had is my 3.5" exhaust sits a little low and the wrap doesn't like getting dragged over speed bumps etc. I've had to re-wrap it a couple of times on those sections.
I used their stainless clamps with no issues. They don't seem like they would hold as tight...but mine haven't moved.
The spray is to protect it from elements a little better. Mud/dirt and stuff. Figured it couldn't hurt.
JIM
#45
10-4 Thanks again Jim..
#46
Gary
