Buying a new clutch--what to get?
I am going to do the clutch on the car--I have used center force clutches in other cars with great success--just wondering what to use on my 65 327/365? McLeod or just generic napa clutch?
thanks
thanks
C2 of Year Finalist (performance mods) 2019
I just installed a Luk in August. It is very smooth and easy to depress. I got it at the local Napa. I do not race the car and I have a 5 speed so I needed the 26 spline disc. I am very satisfied with it.
Hay Mark. I'm gathering all the parts needed to install a Richmond 5-speed with a 26 spline. What Luk part number did you purchase and did you replace your flywheel with a Luk LFW131?.
Why would you not use a Centerforce, since they've been a "great success" for you? I've used the same brand in several Sting Rays.
Since I had it apart I put a new clutch back in and I am very pleased with the Luk. Just do a search on this forum for Luk and you will see the guys love this clutch. Good luck.
I did not use a new flywheel, I just had my old one turned. The part numbers I gave you are Napa numbers. I do not have the Luk numbers.
