Engine ID
Old 11-27-2015, 05:38 PM
GCD1962
GCD1962's Avatar
Default Engine ID
Just bought a '57 Chev, 2-door, 4-Speed. Seller says the engine is a 283 (not original, no road draft outlet). I know it's a replacement block but what would be the codes. On the pad it only is stamped T-101
Old 11-27-2015, 06:52 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Start with getting the block casting number and block casting date. Probably on the upper rear of the block, driver's side (casting number) and passenger's side (casting date).
Also check for any codes or numbers on the sides of the block.
Larry
Quick Reply: Engine ID
