58-62 - Fix for hood release handle coming off
My hood release handle wasn't in the best shape, so I bought a new one. CC will not sell you just the handle...you have to buy the whole cable and handle...BUT Paragon will sell you just the handle.
When I got my new handle, I tapped the handle and the shaft with a 12-24 tap, which requires no pre-drilling. The original handle and shaft are NOT threaded....it is serrated and a press on fit.
The advantage of this is that it's highly unlikely to come off, and should I ever want to take my handle off, I can.
Should you decide to do this, there are some things you should know...
The hood release cable is a SINGLE piece of wire that goes from one hood latch through the handle and over to the opposite hood release latch. The wire is "threaded" through the handle like a needle and thread...so if you tap your shaft, you MUST hold the shaft from spinning when putting on or taking off the handle, otherwise you will twist the wire inside and end up with a sticky (if not stuck) cable.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Would you lose a lot of cable strength is you snipped off the loop before you thread the shaft? Seems to me it would be easier.
I did it another way. I drilled and tapped the handle for a set screw (two actually for safety) and use an allen set screw which tightens right into the shaft. Works so far.
You don't need to snip off the cable (loop)....just thread it right on the car.
I just used some vice-grips and held the shaft from spinning while I tapped it.
