Radiator and Shrould
2023 C1 of the Year Finalist - Modified
I need your help. Purchased a new Brass re-pro radiator and fan shroud assembly (4 piece) for my 59. The radiator lines up with all the holes in the radiator core support and the upper shroud also lines up with all the holes until I install it in the car. Then the radiator is OK but the holes in the shroud are too low to mate up. If I line them up then the upper shroud to lower shroud won't mate up. It sits about 3/4 inch up off the lower shroud so I can't bolt them together
Anyone have some really good close up pictures of the radiator and fan shroud assembly that you can post, or have any good advice on whats wrong.
As always many thanks and Save the Wave
