63 split window + 98Z28 LS1&T56
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
That's a perfect car for a project like that, even without the family history.
The heads on an LS1 breathe pretty good. I'd get a cam and new springs and call it good. Better budget for new brakes though!
I have the front brakes from the Z, and so far I think those will work with brackets from Kore3. (good thing the CAMARO on the calipers is only a sticker ) May get upgraded at some point, but this will already be a TON better than the 4 wheel manual drums that are on there now.
still not sure what I am doing with the rear yet.
it was like an early Christmas today Got the suspension and headers in today.
also got the engine and trany mounts recently, time to lift the body and test fit the motor/trany
Look at the trees in the background looks like the same drag strip I think it was 75 and 80 in Monrovia Maryland.
6 speed manual out of a 1998 Z28 camaro (T56 is what I have always heard them referred to as) is what I will be using.
looks like there is a tremec t-56 (I don't think it is the same thing), but I don't think that is what I have.
http://www.moderndriveline.com/Techn...m_features.htm
Well that will take some time .Only kidding still for the stock outlook
would like to know if its readable since its easy to look at now.
I have a mini body stand set up for my restricted space requirements. I don’t have the ability to just wheel the body to another spot, so I need to be able to stack things. What I do have though is a 2 post lift.
I created a very simple, very small 2X4 frame to set the body on, that width wise the floor boards just fit inside. This makes it so that the stand does not cover access to the bottom of the body mount bolts (I’m not sure where other body dollies rest).
I wanted this, so that I could put eye bolts through the body mount holes to lift the body up, and set it down on the frame to test fit things, easily, over and over. (you can also see the bottom of one of these bolts in the top pic, the shinny bolt on the left)
That will be lifting from the top with straps to those bolts, but with a lift that is designed to lift from the bottom of the car, I only have so much height to lift, when lifting from the top. I also wanted to be able to lift with the arms, lifting the stand and the body all the way up, to get them up out of the way, to work on the frame.
I can also set the body and the stand on the frame rails with the frame under it, just to get inside the car, or get to the top.
If I have the frame pulled out, I can also put the stand directly on the floor.
This is my whole garage, I don’t have room to leave stuff spaced out.
I will add supports up to the front, once I get the core support back in there. Right now it is out, so there is nothing there to hold up.
#34
I bought it and put it together with a friend and a tractor. It is a LOT of bolts.
I had the slab poured, and left a footer open to put the building in, then covered the bottom with more cement in the footer. If I had it to do over, I would have bought the pieces that bolt the building to a flat slab instead of sinking it into the footer, would have been cheaper and easier.
This one is 20X30.
You put the arches together on the ground loose, then stand them up and bolt them together, you need some sort of equipment to stand them up. The tricky part is the first 1-3, getting them to stay standing while you get the next arch. After 3, they are self-supporting and the rest go up easy.
If you have something (tractor, fork lift ect) that can lift the arch up (just tilting it straight up from laying flat, but you pretty much have to lift by the top), at least 2 people, and impact and some time, it is not that hard.
This one is 20X30.
#35
You still have time to reconsider the LS, just speaking from experience but engine swaps take about ten times longer than fixing what's broken. I am just checking that you know that everything that touches the powertrain has to be changed, not one single thing will bolt up wire up or fit up. Have you considered a nice 383 stroker or zz4? it will bolt in without cutting welding, fabricating, inventing, extra spending!
#36
nah, the LS1 part and wiring I can handle, it is the body work and bird cage that scares me. Plenty have done it before me, and I already have most of the parts that almost make it a bolt in swap. That is the fun part
and I already have the motor and trany sitting there:
#37
Tunnel
You will have clearance issues with a stock frame with a T56 6 speed tranny.
Been there.I installed a 2003 LS6 with a 2002 T56 behind it and had to
Change the crossmember.
Street and Performance in Arizona sells the bolt in crossmember.
You cut you crossmember right between the two exhaust holes.
You will also need to purchase a relocation shifter or do what I did and
Pull a mold off the original shifter console and move the hole.
Obviously you are aware that you will be running a Fuel Injected
Tank with pump inside and a radiator set up for the LS also.
Bolting the motor tranny into the frame is simple.
It's when you have the wrong oil pan and that needs changed.
I drilled and tapped a hole in water pump for steam line.
I also had clearance problems with my bibs coming out of my water pump and hitting my A Arms.Had to wald a block off plate on water pump and drill and tap new holes so bibs came out vertically.
Just be ready for one set back at a time with a stock frame.
I would run a 5 speed tremec TKO if it where me.
Have fun
Dave
Have fun
Dave
yzguyfl (01-22-2016)
#38
http://www.brphotrods.com/products/6...tte/index.html
I saw a lot mentioned about street and performance, but when I called them up, they were not making headers anymore. I wanted to get engine mounts, trany mounts and headers all from the same place for this application, and the only one I found still selling it, was from the link above. Seemed kinda high for just a few mounts, but I was hoping it would fit correctly, I should see soon. They claim I don't need to change the crossmember, but they also claimed that I would not need to adjust the tunnel, but we will see about that (I suspect it will need to be raised)
Do you happen to have any pics? or references you used? or care to share any more info? I'm about to start test fitting some major components soon (only messing with this in my spare time)
yzguyfl (01-23-2016)
#40
also just did the first test fitting of the LS1 + t56 in the frame, will hopefully drop the body down tomorrow and see what hits.
