67 steering wheel mounting screws
putting in restored tele column....ready to attach the steering wheel cant find the old ones and coulod use some help,,,cant seem to find the screw size.
looked in AIM.and just says production screws...no size...can get them from Corvette vendors ..but Fastenall just down the street.. I can get them local if I knew the size and length..
Any body out there have the spec's on these ?
Tx
Bluzrocker
Tx
Bluzrocker
If no one helps with size...
Found these at...
these are the ones you need..#342225
www.corvettecentral.com
Found these at...
bluzrocker (12-21-2015)
And use some Loctite when you do reinstall them. The screws can slowly work themselves loose over time.
