NCRS is this possible???
Hello I have a vin 116612 car built date 4 19 7 with a build sheet ident # of 817479
Can a car with vin 116412 be built on 4 21 7 with a ident# of build sheet 818123 after my car build hmmm?
the vin is before my car.
did someone make a 67 L71 cause you cant attach a vin to build sheet.???
Received 6,939 Likes
2015 C2 of Year Finalist
Only NCRS has the ident numbers. And you must pay for the service.
Yes, what you describe is possible. 65-67 Corvettes were built in 2 separate plants. St Louis and AO Smith. VIN numbers and Ident numbers were individually assigned at these locations and not sequential between the two assembly plants.
tc
Received 1,857 Likes
emanusa1 (01-02-2016)
The VINs AO Smith issued to Corvettes were provided by St Louis. I did not mean to imply they generated there own VINs out of thin air. My answer was an attempt to explain how the build date of a later VIN car could appear to be before an earlier VIN car.
The VIN was unknown until the car came out of the body build/paint area and headed for the hard trim line.
okayyyy?
yes they are both S vin's with L71 data sheets just one is 200 units later. one day after my car was built but a vin before my car, weird?
Thanks to john I understand it a bit better now. I think?
Thank you.
Thank you.
L71 cars
16412 was built 200 units (about a day and a half) before 16612 - VINs were assigned sequentially (Ident Numbers were NOT). Ident Numbers were assigned when the plant Production Control Department accepted the dealer order, not when the car was actually built 4-6 weeks later.
well im going by the build sheet. so the build sheet would not be accurate. that cars vin is 116412.
What 3 numbers are handwritten on the lower part of this Build Sheet??
Larry
Larry
Only NCRS can tell you if that tank sheet goes with that VIN number; nobody else knows (unless they have the original Car Shipper or window sticker), as the VIN never appeared on the '67 tank sheet.
