My car is going to be in a TV commercial
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
The commercial is for Hy-per Lube Super Coolant (never heard of it LOL).
Two young ladies are going to be sitting in the car. They will drive it about 300 feet, get out of the car, and walk around it "looking pretty".
I'm a bit apprehensive about letting someone else drive the car. But, I will be there and it's going to be in my local neighborhood where there is very little traffic. Also, I contacted Adam Boca to find out if my car would be covered and he gave it the OK.
I believe the ad will run on the Velocity Channel.
Oh, yes, when they found out my wife has a 2012 Grand Sport, they said they might want to use it, too, in a "make your old car run like a new car" theme.
-- Steve
-- Steve
Received 2,126 Likes
I'm sure you know if this girl knows the difference between a standard trans and an automatic. Dennis
If neither of the gals can shift it then one or the other can sit in your lap while you drive it for the photo shoot. I'm sure the wife won't mind!
Steve
Steve
Anyway Steve - if its two gals in the commercial they should each have their own C2....I can be at Mt. Dora in about 25 minutes in the split window (* SMILE *)...
Steve
Here's a couple of commercials, one with a Mustang and one with another '67 Corvette, this company has done for Hy-per Lube products:
-- Steve
Anyone use this stuff?
-- Steve
Received 5,008 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Good question. They didn't say anything about that. The commercial I'm doing is for their coolant product - Hy-Per Lube Super Coolant. I've read some stuff on the Web about it that sounds pretty good. Haven't read anything really negative about it. No way do I believe their claim of making your engine run 20 degrees cooler, however.
-- Steve
-- Steve
