spring mount anchor plate bolts
Received 6,943 Likes
2015 C2 of Year Finalist
If they are two long your going to crack your rear end cover. It's best to measure
Then measure the thickness of the springs and spring liners. Add to this the thickness of the mounting plate and the bolt lock washers.
Now add everything together and then subtract about 3/16 inch for clearance. Use this bolt length. Cut the bolts if needed.
You should then be good to go.
Larry
