Hood cable
Received 6,929 Likes
2015 C2 of Year Finalist
Lay under the car and reach up at the drivers side hood latch and pull on the lever where the cable hooks up to.
Another timely post for me to add to... I have my hood release cable out for refinishing. Is there anything I can do to ensure the T handle does not come off like this?
It's not fun job to do when your at a show. Trust me I have done it twice. Once dads car other a friends car. Side pipes make it worse. It wouldn't be that bad at home in a garage where you have all kinds of tools at your disposal. But it never works out that way.
Make sure the cable end has a 90* bend after it goes thorough the cable stop and the cable stop bolt is tight. There is nothing you can to to prevent the cable from coming out of the handle it self.
Dave Z
Received 2,126 Likes
Another version of this is when the actual T handle comes off in your hand inside. You can replace the entire assembly or drill, and tap the body for a small set screw. Your car, your decision! Dennis
