Trim Tag Question
Trim Tag Question
I recently purchased a 1967 Corvette. I received the Original Window Sticker, Original Corvette Order Copy and Original Protect-O-Plate still attached to the Warranty Booklet. The vin is 194677S119613.
All numbers relate to the car and confirm its manufacture as an L71--"Big Block". The car did NOT come with Factory Side pipes.
The trim tag shows the Body as, "A-3765".
Can this be correct?
Thanks for any help.
Received 6,929 Likes
2015 C2 of Year Finalist
Well your not going to like where this is going to go. In short I hope you like your car. It's not what you think.
Received 1,856 Likes
The trim tag shows the Body as, "A-3765". The car did NOT come with Factory Side pipes.
If you like the car, nothing else really matters.
What's up is you bought a made up 67 L71, which is not really any big thing, because many others have as well.
More than likely, all the associated paperwork you got with the car is also made up too, which is very common with 67 L71 cars. They are one of the most re-created cars in the classic corvette hobby.
Don't worry about any of the above though, because if you like the car that is all that really matters.
Happy corvetting!
Happy corvetting!
Happy corvetting!
Happy corvetting!
Again, if you would kindly supply me with your email address, I will send several pictures to you of the vin tag, trim tag, Protect-O-Plate still attached to the Original Warranty Book, Original Window Sticker and other Original docs.
I would appreciate you looking at these (objectively) and then rendering an opinion.
I have several hundred, if not at least a thousand, original invoices, checks, credit card invoices, manuals, etc. Many, going back more than 30 years continue to show the same vin and/or trim numbers!
Car photos can be seen here http://www.ebay.com/itm/Flawless-Convertible-Sting-Ray-w-L71-Big-Block-Concours-Complete-Restoration-/281919376934?rmvSB=true and Trim Tag appears real, and that's about it. Would be nice to put the front crossed-flags emblem back on, and reposition the pass wiper to be above the driver wiper so you don't strip the wiper transmission (maybe all that fixed by now, eBay ad is old). Many many things to fix if you want car to appear correct, but none of that will change that it is an AO Smith car and left St.Louis with a 327 engine for sure. Read above post by JohnZ, that is gospel, he was there back then and knows what is what
Rick
You probably want to get in touch with a professional... An above post mentioned Roy Sinor, but I am sure that there are others.
You'll have to forgive the bluntness offered here some times, but its because this scenario happens a lot.
There are people whose day job is faking corvette documents.... and they (collectively) have been doing it now for decades. To the untrained eye, they might look legit, but there are key indicators that, the experts, can identify pretty quickly.
Its always hardest to get spun up after you drop your money on a car.... Usually, you can get an expert to check out a car BEFORE you purchase for a couple hundred bucks.
Water under the bridge though....
The general opinion is that the A O Smith factory lacked some ability to produce the Big Block car... There is some debate about a small number a VERY EARLY big blocks being produced there before GM gave up on the idea and move ALL big block production to the Other factory... St Louis.
On the trim tag from the Blue 67 posted above, the top right number is A-3765, which, I think, translates to the 3, 765 body that A O Smith Produced for the 67 model year corvette.
There are two glaring problems here. IF AOSmith made a Big Block, to even be considered, it would have to have a Low number after the A... probably a 2 or low 3 digit number. Your number is almost to 4 thousand... so we KNOW it couldn't be a Real, off the factory floor BB because they were not making them at that time there.
When one piece of documentation is KNOWN to be wrong, it throws all the rest into question as well.
I'd think that the current market value for a NOM Big Block Clone done well would be 70ish...
You might want to seek a Corvette Professional and Legal council if you feel you have been misled by the seller.
Best of luck
Best of luck
TFE731 (06-03-2018)
I am by means no expert when it comes to paper work. But with the info given I do not need to see it to tell you it's fake. Bottom line is no AO Smith 67 built a BB car after the first week of production.
Received 1,919 Likes
Except that those documents may need to be entered into evidence in the case of any legal actions. However, most of the fakers are pretty good at using weasel words to avoid legal responsibility. It is a good-looking car. I'll leave it to you guys to debate the price point for an elaborate clone.
