Installing front springs trick
Ok, first of all, everyone probably knows about this but I just learned it this week and found it slick as hell.
1. Installing front springs with no motor is a bitch, and the spring compressor is a futile effort.
2. I modified a cheap harbor freight racing jack to accept a 1" chain through the base. And made a pocket on the perch to surround the lower castle nut.
Then wound the chain through the holes and up under the upper a arm brace.
Put a dab of chassis grease on the top of the spring and pry bar it into the upper crown
Take up all the slack and jack up the jack. The chain will tighten and compress the spring then attach the upper a arm
Again this maybe old info for everyone but I though it was worth posting
Yep...
Put it in there, use the old rubber from the trans mount to protect paint/powder coat on top, can't remember where/what the large washer is from....use the metal insert from trans mount on bottom...
Always keep the jack snug as you tighten the nuts, just in case so the spring don't go flying around the garage...
DAN70 (02-08-2016)
I would never install/remove a spring without a chain around the center of the spring and pulled tight. If that compressed spring slips and gets away from you, it can kill you. With a chain through the center and your hands clear you'll at least get to clean you pants.
