Help with an engine year, etc.
Hello. A friend of mine just purchased a very cool 1957 Bel Air hardtop . Somewhere in its history, what looks like an early 60's Corvette motor and 4 speed were dropped in. I am intrigued by the motor as it sounds like a solid cam engine and am trying to identify it. The only numbers I can easily find are what's on the pad in front of the passenger side head. There is no serial number but has "FI204D" stamped on it. Can anyone tell me what this engine is and when it was built from just this sequence? Thanks I've struck out on my own trying to decipher it!
Received 6,943 Likes
2015 C2 of Year Finalist
No offense but every single engine found in any Chevy seems to have came from a Vette
But to really help locate the block casting number located on the back of the block on the flange where the trans mounts
Received 1,857 Likes
You look down behind the dist and firewall and you can see them unless it's a powerglide
You have to look on the bell housing flange at the rear of the block. On the driver's side is a cast #. On the Pass side is the cast date. With the #s in all three places the block can be correctly identified assuming it has not been "messed with." On powerglide cars, the bracket that holds the kickdown linkage on the drivers side can cover up the cast # of the block.
GUSTO14 (02-08-2016)
I am assuming all the numbers are accessible from under the car? IE - if you get the car up and look at the back of the engine from the bottom can you see these casting numbers?
With the engine now residing in a 57 coupe where the hood opens towards the windshield it isn't possible to see the back of the engine from the top. Thanks very much.
With one of these, you should be able to see everything you need to from either above the engine or even below the engine.
Good luck... GUSTO
Rob, if it's important enough to you, try borrowing a borescope from someone, or pick one up on line, they've gotten pretty inexpensive of late.
Good luck... GUSTO
Good luck... GUSTO
I agree but several years ago I tried to buy a 63 FI coupe that had a NOM. The story was that the original motor was in a 57 Chevy in my small city. I tracked down the Chevy but the owner wouldn't sell. I planned to buy both and reunite the FI coupe with its original engine. This was when a 63 FI coupe was worth about $20,000.
