Bleche-White Tire Cleaner
Hi All,
Has anybody used Bleche-White Tire Cleaner. It says in the instructions 'do not let it contact magnesium or aluminium wheels or paint as it can damage the surface'
It seems to me that it would be imposible to clean the tires without some of the cleaner getting on to the wheels.
Has anybody used it and had a problem or has it been OK when it has been in contact with alloy wheels.
Thanks Phil
Thanks Phil
I've been using it for as long as I can remember. If you leave it on the paint, you may see some problems. I just rinse it off the paint when it does get on it. One car I have been using it on, I've owned over 31 years. It still has the original paint.
Received 1,843 Likes
Believe what it says. In concentrated form it will do that. If you wet the wheels and painted surfaces around the concentrated area, you're better off.
"Scrubbing Bubbles" household cleaner works pretty well for whitewalls.
http://www.scrubbingbubbles.com/Prod...m-cleaner.aspx
So does Simple Green, it shouldn't do damage to anything and yes, I've used it on alloys but, can be diluted with water if you don't wish to use it full strength.
Gary
Gary
Diamondback tires recommends against using the bleach products; its prob OK though if you rinse it off really well after use. http://www.dbtires.com/cleaningtips.html
I have only used the original formula. I wasn't aware of the Balck Magic Wesley's nor did I know about the "improved" original formula.
Here is a utube that explains.
dkleather (02-13-2016)
To some extent that language is legalese in respect to lawsuits. But as others have said as long as you wet your surfaces before use & don't let it set too long you should be fine.
Never spray on Hot wheels.
