Looking for My First Mid-Year....Could Use Your Help
I am new to the forum, and looking to buy and build my first Corvette. I am looking for a mid-year that needs a little love. I have a max budget of $35k. I would love some opinions/suggestions on what I should be looking for on the vehicles as I start searching. Any common trouble areas on these cars? Any websites or places you can recommend to help me find a vehicle? Any help is appreciated,
Doug
Doug
Doug
Doug
Big things are frame rust in front of the rear wheel wells (it can be hidden on top of the frame). This is very common and can be catastrophic.
The other area is the birdcage - the steel enclosure around the cockpit. A rusted birdcage is an expensive nightmare to repair.
You should seriously bring someone experienced with these cars with you to look at any potential vehicle. Lot's of BS (intentional or not) with buyers misrepresenting the originality, numbers matching or not, fake protecto plates, and more.
Be aware that there is very little interchangeability with Corvettes - you can't just cruise down to the local boneyard to get parts. Almost every part is specific to the Corvette.
Get to know the years and options offered - lots of nonsense with buyers claiming "rare" this and that.
I don't want to discourage you but I also don't want anyone to learn the hard way like I did.
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Buy a car that someone else has poured a ton on money into and wants out.
Good info. I have already inspected a few cars. With my budget, matching numbers probably won't come into play. I am aware of the frame rust issue. What is the best way to check for a rusted birdcage? Where can you see it the best?
Doug
Doug
Received 2,127 Likes
If you can't remove the glove box, get low and look up behind the box and behind the gauge cluster. It's not easy, but can be done. If it's a coupe, add the rear door jamb area. It can show bubbling under the paint. Dennis
We got waaay under the dash from end to end, removed the kick panels (4 screws) and looked up and down the A pillars, and pulled the rocker panel access covers (again, 4 screws).
Everything "looked" good but just to be sure, wherever possible, such as the bottom of the A pillar, I poked down and tapped with the hammer. Thuds good, crunches BAD!!!
Did the same with the frame since fortunately, there was a lift available. I'm sure that there's more and possibly better ways but that's what I did.
Gary
