'65 Seat Belt Parts and Photos Needed
Previous owner removed the seat belts and put in new carpet. Need seat belts with all the crazy drivers here in Ca. Can someone send me photos of where the floor belt mount holes are and a list of parts needed? Can't see any mount holes with the carpet down. Thanks!
Received 6,943 Likes
2015 C2 of Year Finalist
All the parts needed is shown in your AIM
They are in the corners of the floor behind the seats
AIM doesn't have a good picture of the seat belt system under the seating section. If someone has a picture that would be helpful. I plan to use a sharp pick to find the mount holes in the floor. I assume the seats need to be removed.
Yes remove the seats. If you look from the under side you will see the inside mounts
The attached PDF should get you going. Check out the catalogs of all the major vendors. Lots of good diagrams available in print and on-line. I have used Paragon's illustrations but others are very good as well. Does your car have the reinforcement plates, anchor cables, etc.?
Hope this helps.
Dave Z
Larry
Hope this helps.
Dave Z
Hope this helps.
Dave Z
