67 conv filler neck seal
I have not had this car very long, just ordered a manual for repair, is it possible to remove the rubber boot between body and filler neck to replace the cork seal of the filler neck to tank. Thanks Ian
Just be careful with the drain nipple on the boot............although it is not hard to redo if necessary. Maybe it is just easier to disconnect the drain hose from the boot to improve your work access.
Since your car is a 1967, you can also check for the tank sticker while you are there.
Larry
Larry
You may want to order two seals - those tank filler neck flanges are a bit wavy and might need the extra thickness...make sure you get the right filler neck attaching screws too. The correct ones have an integral rubber piece for proper sealing. Make sure your gas cap is in good shape; that can contribute to the raw gas odor.
The filler neck screws are p/n 3767804; you'll need 9 each. I was able to buy them from local Chevy dealer recently, but they had to order from warehouse which took a few days.
While you're in there, determine if you have a GM replacement gas tank. GM SERVICE fuel tanks for all 63-69 Corvettes after about 1970 included an integral pressure-vacuum valve. When this tank is used, GM instructs that a sealed (non-vented) fuel cap should be used. This is exactly the same as the PRODUCTION configuration for all 1970-74 Corvettes & will reduce fuel vapor smell.
Once your filler neck is off, look about 4" toward the driver's side using a dental mirror (held tightly). Service replacement tanks will have a valve there, ~1" dia projecting near the top of the tank. Original tanks will not. If your tank has this valve, then recommend you use the non-vented '70-'74 version cap for best fuel smell control.
As Frankie says, recommend using two cork gaskets & don't over-torque the machine screws upon reassembly as the thin flange puckers easily. Keep debris out of the tank while cleaning the mating surfaces. I've used a funnel to cover the hole, but you'll still have to be careful not to scrape stuff in through the 9 female threaded holes while cleaning tank surface.
I used a thin coat of clear silicone sealant, spread it on carefully before installation. It helped hold it in place and I figured it would protect the cork and make it last for another 40/50 years or so!
Maybe I missed it but just thought I'd mention this. Once you've removed the filler neck be sure to check the screw holes to see if any were sucked down due to over tightening. If so flatten them out before re-installation.
While everyone has their own way of doing things that's easiest for them I found that if I started the screws into the gasket with just a few turns, to keep them in place, I could then carefully put the neck in place then tighten each of them down a little at a time instead of trying to insert one screw at a time. Just another way to do it.
Another thing I did before I replaced the gasket was to fill the tank so that any old material would be easier to retrieve (since it will float) and got a small fish tank net in case some fell in.... which it did.
Gary
Gary
I pre-started the screws too - and a thin layer of Permatex kept things in place..
The cork has been working fine for a year now, and, it worked for the 50+ years before that. No, you can't crank down on the screws like there's no tomorrow - not only can it mess up the gasket you can easily split the integral rubber on the mounting screws....
Guess what ? I only use cork valve cover gaskets too!
Do the screws have o-rings, the reason I ask is because my 67 needs a new cork gasket and I want to reuse the screws if it's just a matter of replacing the o-ring.
Using silicone sealer takes care of that problem too! It's great - unless you are concerned about a potential NCRS level judging inspection in this area...............
