Key Switch Wiring Help!
Old 03-12-2016, 01:45 PM
Jeht
Jeht's Avatar
Default Key Switch Wiring Help!
I have removed the switch from the cluster with all my wires disconnected. The previous owner had installed an alarm system from 70's era. The company that I purchased car from installed a new switch (wired and left exposed on carpet) rather than fix the issue and failed to correctly repair!
My question is without having diagram, what color wires connect to the original switch (batt, Acc, grnd..........).
If anyone could help with this would make my life easier correcting their screw up!
Appears to be brown wire, red, purple, pinkish
Thanks in advance
Old 03-12-2016, 02:11 PM
BADBIRDCAGE
Support Corvetteforum!
BADBIRDCAGE's Avatar
Received 1,974 Likes on 1,057 Posts
Thanks in advance
We need a year and you need a wiring diagram.
Old 03-12-2016, 02:17 PM
rtruman
rtruman's Avatar
Thanks in advance
This should get you started for a 63 corvette
Old 03-12-2016, 02:18 PM
Jeht
Jeht's Avatar
1966, sorry about that
Old 03-12-2016, 02:20 PM
rtruman
rtruman's Avatar
I think its the same red ,pink ,brown ,purple
go on Google images and you will find what you need.
Jeht (03-12-2016)
Old 03-12-2016, 02:44 PM
buns
buns's Avatar
Best I got and there is no ground.
Jeht (03-12-2016)
Old 03-12-2016, 06:15 PM
rtruman
rtruman's Avatar
That should fix him up nice picture did you use a cell phone .
Old 03-12-2016, 06:51 PM
Jeht
Jeht's Avatar
Just what I needed, thanks to all.
Old 03-13-2016, 08:30 PM
Jeht
Jeht's Avatar
Luckily the wires were just unplugged rather than being cut! Switch wires connected and back the correct way.
Thanks everyone for the help.
To Key Switch Wiring Help!
Quick Reply: Key Switch Wiring Help!
